I would like to install speedtest. Any ideas?
pip install speedtest-cli
Since this is in pip, just use that.
It was a long time ago, if memory serves, I downloaded the x86_64 binary (download for Linux)
dropped the speedtest binary in:
/usr/local/bin
and man page speedtest.5
/usr/man/man5/
Set the execute bit on permissions for user.
Actually, I seems to be I have this one:
I cd to current local dir:
wget -O speedtest-cli https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py
chmod +x speedtest-cli
Then copied to:
/usr/local/bin
Anyway, both work by dropping binary in location ![]()
