error: Failed to install com.spotify.Client: While downloading http://repository.spotify.com/pool/non-free/s/spotify-client/spotify-client_1.1.26.501.gbe11e53b-15_amd64.deb: Connection terminated unexpectedly
I got this error while trying to install Spotify. I got the same error while trying to install it through the Software Store. Any help?
ahkok
2
Well deb
files aren’t going to work for you, at all. There’s no way to install them.
I suggest using the flathub version. If there are any download errors, try again, they may have a service issue at flathub.org and best to tell them
flatpak install flathub com.spotify.Client
Use the flatpak like @ahkok has suggested, it works very well. I updated about 30 minutes ago without any error, it may just was a temporary problem.
