Succesfull installation wont boot
[ 1.605904] sched_ext: Failed to register kfunc sets (-22)
it only gives this error and nothing else. The live edition is okay, the installation okay. I tried latest build and also a former build to try if hepls. The same problem.
Did you check UEFI / BIOS settings ?
Often a motherboard firmware update solves these issues.
Someone posted about this issue on Clear Linux’s Github page so this might be a known bug. Here is the link.
I have the same error, coming from a 42100 updated to 42870. In my case, the operating system boots. I noticed this by checking the logs with the command: dmesg. Therefore, I think that this might not be the source of the problem.
#Board: HP 2B47
#Kernel: 6.12.9-1535.native x86_64
#Processor: Intel(R) Core™ i7-6700 CPU @ 3.40GHz (6/94/3)
