Following this guide here Clear Linux* OS using virt-manager — Documentation for Clear Linux* project
After installing the bundles, enabling the systemd service, rebooting the pc, I tried the usermod command. got this error
[sss_cache] [confdb_init] (0x0010): Unable to open config database [/var/lib/sss/db/config.ldb]
Could not open available domains
No matter, lets see what virt-manager is up to
Unable to connect to libvirt qemu:///system.
Failed to connect socket to '/var/run/libvirt/virtqemud-sock': No such file or directory
Libvirt URI is: qemu:///system
File "/usr/share/virt-manager/virtManager/connection.py", line 923, in _do_open
self._backend.open(cb, data)
File "/usr/share/virt-manager/virtinst/connection.py", line 171, in open
conn = libvirt.openAuth(self._open_uri,
File "/usr/lib/python3.12/site-packages/libvirt.py", line 147, in openAuth
raise libvirtError('virConnectOpenAuth() failed')
libvirt.libvirtError: Failed to connect socket to '/var/run/libvirt/virtqemud-sock': No such file or directory
I honestly don’t know where to begin with this.
EDIT: looks like sssd.service is missing in clear’s sssd package sssd/sssd.spec at 10e0e929a6a95baab78bededd7b3dad3fd82c73e · clearlinux-pkgs/sssd · GitHub . it’s available in fedora’s but I’m not sure how applicable this is https://src.fedoraproject.org/rpms/sssd/blob/rawhide/f/sssd.spec
Run
sudo systemctl start libvirtd
or reboot the system.
I dont get the error on the usermod command anymore but the virt-manager issue is still there
But, have you rebooted the system? or have you run the systemctl command?
This happens when you don’t have the daemon running because the daemon opens a socket to virt-manager and connects to it.
seems like libvirtd doesnt start after reboots even though its enabled, so here’s my process
sudo systemctls status libvirtd
○ libvirtd.service - libvirt legacy monolithic daemon
Loaded: loaded (/usr/lib/systemd/system/libvirtd.service; enabled; preset: disabled)
Active: inactive (dead)
TriggeredBy: ○ libvirtd-admin.socket
○ libvirtd-ro.socket
○ libvirtd.socket
Docs: man:libvirtd(8)
https://libvirt.org/
i@clr~ $ sudo systemctl start libvirtd
i@clr~ $ sudo systemctl status libvirtd
● libvirtd.service - libvirt legacy monolithic daemon
Active: active (running) since Tue 2024-06-25 17:19:01 +08; 2s ago
TriggeredBy: ● libvirtd-admin.socket
● libvirtd-ro.socket
● libvirtd.socket
Main PID: 3689 (libvirtd)
Tasks: 20 (limit: 32768)
Memory: 9.8M (peak: 10.4M)
CPU: 89ms
CGroup: /system.slice/libvirtd.service
└─3689 /usr/sbin/libvirtd --timeout 120
Jun 25 17:19:01 clr systemd[1]: Starting libvirtd.service...
Jun 25 17:19:01 clr systemd[1]: Started libvirtd.service.
then I do a reboot to only find that the service is enabled but service isnt started
virt-manager
then it works,
TLDR: the service doesnt start automatically after a reboot
NOTE: sssd.service is not required for this
Could you mark my solution as solved?
Could you check the errors:
sudo journalctl -u libvirtd.service?
i@clr~ $ sudo journalctl -u libvirtd.service
Jun 24 23:43:12 clr systemd[1]: Starting libvirtd.service...
Jun 24 23:43:12 clr systemd[1]: Started libvirtd.service.
Jun 24 23:43:29 clr systemd[1]: Stopping libvirtd.service...
Jun 24 23:43:29 clr systemd[1]: libvirtd.service: Deactivated successfully.
Jun 24 23:43:29 clr systemd[1]: Stopped libvirtd.service.
-- Boot 17643901efd541108b99d50cb8e43833 --
Jun 25 17:15:28 clr systemd[1]: Starting libvirtd.service...
Jun 25 17:15:29 clr systemd[1]: Started libvirtd.service.
Jun 25 17:16:14 clr systemd[1]: Stopping libvirtd.service...
Jun 25 17:16:14 clr systemd[1]: libvirtd.service: Deactivated successfully.
Jun 25 17:16:14 clr systemd[1]: Stopped libvirtd.service.
-- Boot ee4390018d084d8e9b1d5064ddcc7c1a --
Jun 25 17:21:01 clr systemd[1]: libvirtd.service: Deactivated successfully.
seems like it deactivates itself
I have to always start libvirtd before doing anything it deactivates way too fast lol
Could you print the output?
virsh net-dumpxml default
I’ve got my VM up and running, but here you go
i@clr~ $ virsh net-dumpxml default
error: failed to get network 'default'
error: Network not found: no network with matching name 'default'
virsh net-autostart default
i@clr~ $ virsh net-autostart default
Open or create :
/usr/share/libvirt/networks/default.xml
Edit :
<network>
<name>default</name>
<bridge name="virbr0"/>
<forward mode="nat"/>
<ip address="192.168.122.1" netmask="255.255.255.0">
<dhcp>
<range start="192.168.122.2" end="192.168.122.254"/>
</dhcp>
</ip>
</network>
Then :
virsh net-define /usr/share/libvirt/networks/default.xml
virsh net-start default
