Setting up a new VM in VMM : Issue
My current release of Clear is
Current OS version: 42410
Latest server version: 42410
There are no updates available
I installed the bundles supporting the Virt/QEMU system with the VMM GUI manager.
Perhaps I am spoiled but after the bundles were loaded, systemctl did not restart the libvirt. process. (so I did)
Next, I tried to created a new VM, but in the network choice, the field was blank with no drop down choices.
By default, the usual choices are
-NAT
-Bridge
-macvtap
So I ran a service check on libvirtd and got the following:
libvirtd.service - libvirt legacy monolithic daemon
Loaded: loaded (/usr/lib/systemd/system/libvirtd.service; enabled; preset: disabled)
Active: active (running) since Sun 2024-09-29 22:45:50 EDT; 5min ago
TriggeredBy: ● libvirtd-ro.socket
● libvirtd.socket
● libvirtd-admin.socket
Docs: man:libvirtd(8)
https://libvirt.org/
Main PID: 4832 (libvirtd)
Tasks: 21 (limit: 32768)
Memory: 95.3M ()
CGroup: /system.slice/libvirtd.service
└─4832 /usr/sbin/libvirtd --timeout 120
Sep 29 22:46:21 clr-3e41015f01014fefb614cc118803ca84 qemu-system-x86_64[5167]: HARK log.c: 92: core_log_lib_info: src version: 2.1.0
Sep 29 22:46:21 clr-3e41015f01014fefb614cc118803ca84 qemu-system-x86_64[5167]: HARK log.c: 94: core_log_lib_info: compiled with support for shutdown state
Sep 29 22:46:21 clr-3e41015f01014fefb614cc118803ca84 qemu-system-x86_64[5167]: HARK log.c: 97: core_log_lib_info: compiled with libndctl 63+
Sep 29 22:46:21 clr-3e41015f01014fefb614cc118803ca84 qemu-system-x86_64[5176]: HARK log.c: 92: core_log_lib_info: src version: 2.1.0
Sep 29 22:46:21 clr-3e41015f01014fefb614cc118803ca84 qemu-system-x86_64[5176]: HARK log.c: 94: core_log_lib_info: compiled with support for shutdown state
Sep 29 22:46:21 clr-3e41015f01014fefb614cc118803ca84 qemu-system-x86_64[5176]: HARK log.c: 97: core_log_lib_info: compiled with libndctl 63+
Sep 29 22:48:28 clr-3e41015f01014fefb614cc118803ca84 libvirtd[4832]: libvirt version: 10.7.0
Sep 29 22:48:28 clr-3e41015f01014fefb614cc118803ca84 libvirtd[4832]: hostname: clr-3e41015f01014fefb614cc118803ca84
Sep 29 22:48:28 clr-3e41015f01014fefb614cc118803ca84 libvirtd[4832]: XML error: interface type=‘bridge’ requires a ‘source’ element
Sep 29 22:48:36 clr-3e41015f01014fefb614cc118803ca84 libvirtd[4832]: XML error: interface type=‘bridge’ requires a ‘source’ element
So it seems there is no network interface in the virtual network manager defined as “bridge” and tosses out an error. Just like in the VMM install, where certain items are turned on by default in other Linux OS’es, Clear seems to skip that part.
By design, or just missed in testing? Thought I would ask.
Hi Edwaleni,
I found that you need to manually define your networks and storage. Especially if you are using a bridge, this will need to be created first either via Network Manager or systemd-networkd then defined.
Kind Regards
Thank you for the feedback.
