android@clr~ $ tracker daemon -t
Found 0 PIDs…
android@clr~ $ tracker daemon -s
Starting miners…
(tracker daemon:3643): Tracker-CRITICAL **: 12:05:41.315: Could not create proxy on the D-Bus session bus, Error calling StartServiceByName for org.freedesktop.Tracker1.Miner.Files: Unit tracker-miner-fs.service not found.
(tracker daemon:3643): Tracker-CRITICAL **: 12:05:41.317: Could not create proxy on the D-Bus session bus, Error calling StartServiceByName for org.freedesktop.Tracker1.Miner.Extract: Unit tracker-extract.service not found.
(tracker daemon:3643): Tracker-CRITICAL **: 12:05:41.317: No D-Bus proxy found for miner 'org.freedesktop.Tracker1.Miner.Files'
✗ File System (perhaps a disabled plugin?)
(tracker daemon:3643): Tracker-CRITICAL **: 12:05:41.317: No D-Bus proxy found for miner 'org.freedesktop.Tracker1.Miner.Extract'
✗ Extractor (perhaps a disabled plugin?)
android@clr~ $ tracker daemon -f
Store:
07 May 2020, 12:06:25: ✗ Store - Unavailable
Miners:
07 May 2020, 12:06:25: ✗ File System - Not running or is a disabled plugin
07 May 2020, 12:06:25: ✗ Extractor - Not running or is a disabled plugin
Press Ctrl+C to stop
it doesnot index my removable folder/partition(NTFS).
