Hi again,
Wondering if anyone out there chose Clear Linux as their solution for a storage platform?
I see there’s a tutorial for ZFS and a storage-cluster swupd - in regards to the storage-cluster swupd, is that only gluster, or is there an option to use another technology like ceph? (In another swupd?)
Are there some customization options if one were to install a swupd for storage-cluster? For instance, if one were to install a ceph platform, would there be ways to implement setup using bluestore for block devices instead of xfs+lvm?
Lastly, container storage platforms like OpenEBS or longhorn - are those only an option after installing an orchestration system like kubernetes, or can they be implemented independent of the kubernetes cluster?
Thanks
