I got chrome working on Clear Linux, simply put its not the most ideal way but non the less it works.
Downloaded Official .rpm from Google
Extracted Contents of .rpm
Moved Contents into folder named Google Chrome created in Main Home dir.
Used Gnome-Terminal cd into /home/username/Google Chrome/opt/google/chrome
executed ./google-chrome from Terminal
Everything works including Extensions, Netflix, etc. The one think I noted was fonts are not system fonts. Not ideal way to get Chrome but working non the less.
