Hi everyone! How can I burn a distribution onto a multiboot flash drive? Ventoy and Rufus interrupt the installation at the very beginning
The one we document for creating a Clear Linux boot USB drive is Balena Etcher - balenaEtcher - Flash OS images to SD cards & USB drives. But I don’t know how or if it handles multiboot flash drives.
Edit - fixed typo and added a link.
Chris
Thanks for your reply! I’ll try to use this
Hi Jerome_Stull,
I use MultiBootUSB : it works perfect …
You can install multiple LiveUSB and even Add LiveUSB or remove LiveUSB later on.
You can Add also Writable Remanent Partitions to work on it …
https://github.com/mbusb/multibootusb
This may be work :
wget "https://rpmfind.net/linux/openmandriva/cooker/repository/x86_64/main/release/multibootusb-9.2.0-4-omv4090.x86_64.rpm";
rpm2archive multibootusb-9.2.0-4-omv4090.x86_64.rpm;
tar xvf multibootusb-9.2.0-4-omv4090.x86_64.rpm.tgz -C / ;
Perso I use MultiBootUSB on SOLUS :
It is very simple and User Friendly
