Has (again) tried to start adb - fastboot, but gets the error message: “adb: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory”
Have tested some solutions I found when searching online, but none of these worked.
I intend to install Grapheneos.org on a Google Pixel 4a, but tested adb - fastboot on a Samsung Galaxy S8.
I have approved usb debugging under developer options on mobile.
Anyone with any suggestions?
I’m using adb with the newer version of ncurses. Try the updated version of ncurses first with the devpkg-ncurses
bundle. If that doesn’t work, the compat-common
bundle has the older ncurses libs.
