Hi all,
I installed Slurm as a queue system about 5 years ago compiling from the source.
Some weeks ago I started to get the following error when I try to use scontrol:
(base) rene@h001~ $ scontrol -h
scontrol: error while loading shared libraries: libncurses.so.6: cannot open shared object file: No such file or directory
I checked in /usr/lib64 for the libncurses files:
(base) rene@h001/usr/lib64 $ ls -l libncurses*
-rw-r–r-- 1 root root 18 Jul 19 03:09 libncurses.so
lrwxrwxrwx 1 root root 16 Jul 19 03:09 libncursesw.so → libncursesw.so.6
lrwxrwxrwx 1 root root 16 Jul 25 08:50 libncursesw.so.5 → libncursesw.so.6
lrwxrwxrwx 1 root root 18 Jul 19 03:09 libncursesw.so.6 → libncursesw.so.6.4
-rwxr-xr-x 1 root root 787024 Jul 25 00:33 libncursesw.so.6.4
Even if I create the symbolic link, I get the error:
(base) rene@h001/usr/lib64 $ scontrol -h
scontrol: error while loading shared libraries: /usr/lib64/libncurses.so.6: file too short
A search for libncurses.so.6 with swupd search-file also returns no results and I have the compat-common bundle installed.
Where can I find the libncurses.so.6 library for CL? My version of CL is 39780.
EDIT: I created a symbolick link to libncursesw.so.6. But is this the correct procedure?
