Hi!
My understanding of Clearlinux is that there is a set of rpm packages forming a bundle, which then gets installed into the system. Now while debugging a problem I found that /usr/lib64/libm.so.6 as of version 38050 is causing unexpected floating-point exceptions in a LISP compiler I am debugging, while the version in https://cdn.download.clearlinux.org/releases/38050/clear/x86_64/os/Packages/libc6-2.36-559.x86_64.rpm does not. This came as a surprise to me since my expectation was that /usr/lib64/libm.so.6 comes through the os-core bundle, which itself is built from the library in https://cdn.download.clearlinux.org/releases/38050/clear/x86_64/os/Packages/libc6-2.36-559.x86_64.rpm. But since the file in that package is totally different from the one in the installed system apparently my understanding of the mechanism is wrong or at least has some gaps. Could someone explain to me how it comes that the file in the installed system is different from the file in that package?
Robert
