I installed CL recently. The first impressions are very positive at least.
During the system configuration, I installed the desktop-autostart bundle (bundle-add). Since I didn’t like the result, I uninstalled it (bundle-remove). Unfortunately, the Applications menu became corrupted. Each time I press the Applications icon, the message appears:
Error
Failed to load the applications menu.
File "menus/xfce-applications.menu" not found.
Close
I am not sure concerning the bug; maybe I made a mistake.
Upon bundle-add desktop-autostart, more than 800 MB packages installed and the desktop changed its look-and-feel completely. In addition, after its removal, the same numerical simulation (my primary interest) run more than 2% faster.
The bundle install GDM and you are likely to be brought into Gnome instead of xfce4.
Gnome does use more system resources than xfce4. But how many times have you benchmarked the difference in your numerical simulation? Is the 2% difference consistent or due to other random factors like your local temperature or even voltage stability?
If the difference is persistent, then you’s better uninstall any desktop environment, that’d be even faster.
Desktop autostart includes desktop which includes a number of other bundles. Removing desktop-autostart does not remove the includes added from it today so you’ll have to go through and manually swupd bundle-remove things that are likely impacting you (I’d start with desktop desktop-apps desktop-gnomelibs desktop-assets desktop-locales and see how that goes, some of those might not be removable because they are used by other bundles on your system though).
I have successfully uninstalled desktop; desktop-apps; desktop-assets; and desktop-locales. However, desktop-gnomelibs is used by 15 other bundles, and hence unavailable.
Referring to a Bundle List, too much bundles are included and inter-related. It seems that a clean install is a more feasible solution.
