I just tried Package golang · GitHub and it seemed to be almost right (it looks like we have a slight bug around timing of the job run as the newest release wasn’t actually available Version on server (42390) is not newer than system version (42390)
). But otherwise images are available. Are you seeing the content at all?
Yes, I see the versions. Sorry, I did not check before asking… It seems to work now!
Thanks for following up
looks like this wiki page needs to be updated, as it points to all the old docker hub locations:
https://www.clearlinux.org/clear-linux-documentation/get-started/containers/container-images.html
yup. Thanks for flagging that. There’s a lot of outdated info on the documentation site unfortunately, and we also need to get the updating process a bit more automated. It’s a manual process right now, which makes it a bit cumbersome to update.
Any updates there, @alexjch ?
Hi @william.douglas, I was just checking Packages · Clear Linux* Project · GitHub and I noticed that the CI is failing for some packages (I’ve checked mariadb and golang) for 26 days… Any idea what is going wrong?
Thanks!
Sorry, I fixed this but just realized I didn’t respond. The issue was related to how bundle content changed and underlying dockerfiles needing to be adapted to the updated content.
