Battlemage: CL support for Arc B580?
Any plans to support the upcoming Arc B580?
The B570 is a tiny bit more efficient, at 40 Watts less.
My sources* tell me that you should be able to make it work -
They’ll need 6.12 or mainline and a git build of Mesa
And also mentioned that
It should be supported but perf may not be optimized because of the Xe DRM being default
Chris
  • Check out the Intel Insiders Discord for all the latest Intel Arc info
The link, for anyone who doesn’t know how to join:
