borgbackup offers several compression options for backup archives, including lz4, zstd, zlib, and lzma. Unfortunately, in removing the tainted xz from everything we can, borg on Clear Linux also loses lzma support. If you’re not using lzma in your archives, you shouldn’t have an issue; borg will continue working with any of the other three (or none). But if you do, you won’t be able to read those existing archives unless you install Python lzma support manually.
I’m adding a bundle, xz-lzma-i-accept-the-risks, that will provide Python lzma support. If you add this bundle, borg operations on lzma archives should work. Without it, borg will fail on those archives. I recommend installing this only long enough to convert those archives to a different compression algorithm like lz4 or zstd.
