Hi, I am currently using Archlinux and am interested in trying Clear Linux and I understand that things are a bit different here, but this is normal. I would like to use the system to build OpenWrt among other things. Actually I do it without problems on Arch. But I don’t know if it is equally possible for addictions. The dependencies for various Linux distributions are listed on the OpenWrt page, but not for Clear Linux. Has Qulacuno already tried to do it? Can you give me suggestions?
I would swupd search and/or swupd search-file the dependencies that are listed in the “how-to” for compiling on other distros to see if the dev packages are available on Clear Linux. If it does, swupd bundle-add it. If anything is missing, you’ll probably have to compile it and install locally.
