The lsusb says cmabridge semiconductor radio hci mode …
How to configure this adapter to work in clear linux
You might need to use usb-modeswitch
. Check what people have done to make it work in other Linux distributions as well.
@Sam
Well, I have a Chinese CSR (not CRS) bluetooth 4.0 dongle and it’s working.
What do you see when you run lsusb
in shell?
It should be something like:
Bus 001 Device 012: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Yes… I have the same one… Lsusb also shows the same… How did you make that work… Which version are you using?
What do you mean by version
I’m on the latest version of Clear Linux.
Have you done something to make it work… Plz help me its not working for me…the local shops only have these adapters here
It just works out-of-box.
What do you mean by not working?
I mean nothing is showing up… In top panel
It’s also not working in other Linux distro like Ubuntu… But works well on old Linux kernel versions
Can you see anything in Settings
And I don’t understand what do you mean by nothing is showing up in top panel
Isn’t that expected?
What do you see in the Settings
What’s the output of
systemctl status bluetooth
bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; disabled; vendo>
Active: active (running) since Sun 2020-04-26 06:43:40 UTC; 11min ago
Docs: man:bluetoothd(8)
Main PID: 913 (bluetoothd)
Tasks: 1 (limit: 9377)
Memory: 2.6M
CGroup: /system.slice/bluetooth.service
└─913 /usr/libexec/bluetooth/bluetoothd
Apr 26 06:43:40 clr-live systemd[1]: Starting Bluetooth service…
Apr 26 06:43:40 clr-live bluetoothd[913]: Bluetooth daemon 5.52
Apr 26 06:43:40 clr-live systemd[1]: Started Bluetooth service.
Apr 26 06:43:40 clr-live bluetoothd[913]: Starting SDP server
Apr 26 06:43:40 clr-live bluetoothd[913]: Bluetooth management interface 1.14 i>
lines 1-15/15 (END)
bluetoothctl power on
And does that turns your bluetooth controller on?
No default controller available
Earlier you said
But I cannot see the CSR dongle in your screenshot. Can you post the output of lsusb
here?
Silver April 26
Earlier you said
Sam:
lsusb
here?
Visit Topic or reply to this email to respond.
In Reply To
April 26
To unsubscribe from these emails, click here.
