I’m new to Clear Linux and tried it on my Asus ux360 laptop. everything works like a charm just the CPU fan keeps running all the time and I’m looking for instructions to setup and configure CPU fan control. I tried to build “notebook fan control”, but it seems clear Linux doesn’t support the required modules. any help in this regard or any other solution? thanks in advance.
Can you check if the asus-nb-wmi kernel module is loaded? sudo lsmod | grep asus
If not, try to load it: sudo modprobe asus-nb-wmi
After that the standard utilities to manipulate fan speend should work (lm-sensors, tlp, thermald, etc).
This is good resource too: Fan speed control - ArchWiki
thanks for your reply.
yes, the asus-nb-wmi kernel module is loaded but none of the standard utilities like lm-sensors, tlp… changes fan speed on my system(they show fan speed but can’t change it). I’ve tried everything mention in Fan speed control - ArchWiki
but none of them was successful.
Hi…I have 5 3 pin fans, 2 of them are working pretty nicely I think since they are at least listening to me, I found out that I can turn them off until something reaches temperature x, but I don’t hear any difference because one connected to CPU_OPT is running at full speed all the time
If what I’ve read is correct, I can control speed of 3 pin fans unless I connect one to CPU_OPT/FAN, then they have to be 4 pin, and one is not so that’s probably my issue.
The functionality of fan headers depends on the specific motherboard/manufacture. You should look into the details in your system’s manual and UEFI. Some do offer DC speed control for 3-pin fans and sometimes it is only available on select 3-pin headers.
