I run pwmconfig to set my fan speed, and give me output like this
Found the following devices:
hwmon0 is coretemp
hwmon1 is AC0
hwmon2 is acpitz
hwmon3 is asusFound the following PWM controls:
hwmon3/pwm1 current value: 170
hwmon3/pwm1 is currently setup for automatic speed control.
In general, automatic mode is preferred over manual mode, as
it is more efficient and it reacts faster. Are you sure that
you want to setup this output for manual control? (n) yGiving the fans some time to reach full speed…
Found the following fan sensors:
cat: hwmon3/fan1_input: Tidak ada perangkat atau alamat seperti itu
hwmon3/fan1_input current speed: RPM
I got this output while run fancontrol
$ fancontrol
Loading configuration from /etc/fancontrol …Common settings:
INTERVAL=10Settings for hwmon3/pwm1:
Depends on hwmon0/temp2_input
Controls hwmon3/fan1_input
MINTEMP=20
MAXTEMP=50
MINSTART=150
MINSTOP=0
MINPWM=0
MAXPWM=230
AVERAGE=1Error: file hwmon3/pwm1 doesn’t exist
At least one referenced file is missing. Either some required kernel
modules haven’t been loaded, or your configuration file is outdated.
In the latter case, you should run pwmconfig again.
so i tried to see the directory
ls /sys/class/hwmon/hwmon3
device fan1_label power pwm1_enable temp1_input
fan1_input name pwm1 subsystem uevent
i can’t use sudo cat /sys/class/hwmon/hwmon3/fan1_input to print it to terminal
but i can set my fan speed by using
sudo bash
echo 200 > /sys/class/hwmon/hwmon3/pwm1
How to get fancontrol working?
