Dualboot with Windows 10. Bootloader problem
Hi. I installed Clear Linux alongside Windows 10. I want to be able to choose either window or linux in the bootloader. I followed your instructions https://tiny.pl/7ntmg
I have a problem like on the screen. Can You help me? Thank you…
check the command again, it should be
sudo mount /dev/nvme0n1p5 /mnt/clearlinux/boot
You’re right. My mistake. Works beautifully. Thank you very much.
