Using AWS EC2, ClearLinux AMI (latest).
Problem begins with this message when the host boots
[ 0.146721] x86/mktme: No known encryption algorithm is supported: 0x0
libbpf: failed to find valid kernel BTF
libbpf: Error loading vmlinux BTF: -3
libbpf: failed to load object 'iterators_bpf'
libbpf: failed to load BPF skeleton 'iterators_bpf': -3
Failed load could be due to wrong endianness
So, I Google around.
- Make sure I have
pahole
installed - Follow the ClearLinux Kernel Development Guide → recompile
kernel-aws
withCONFIG_DEBUG_INFO=y
andCONFIG_DEBUG_INFO_BTF=y
added to theconfig-fragment
file - Install new kernel RPM with
rpm2cpio armen-linux-aws-5.15.75-351.x86_64.rpm | (cd /; cpio -i -d -u -v);
- Update bootloader, set the correct kernel, and reboot as per the Kernel Dev Guide
- Still seeing the same errors
- Cannot stat or find
vmlinux
→stat /sys/kernel/btf/vmlinux
- Install the rest of the generated rpm files from the kernel build
make
step with:
rpm -Uvhi armen-linux-aws-license-5.15.75-351.x86_64.rpm --nodeps
rpm -Uvhi armen-linux-aws-extra-5.15.75-351.x86_64.rpm --nodeps
rpm -Uvhi armen-linux-aws-dev-5.15.75-351.x86_64.rpm --nodeps
clr-boot-manager update
shutdown -r now
…Still no luck. Can someone help me understand how to get vmlinux + btf + libbpf
working properly, please?
