I am trying to install Nextcloud on Clear Linux. This is more playing around to learn about Clear Linux than anything else.
I can get to the Nextcloud installation wizard page and it will let me enter the admin user and database info and will accept it. However, when I try to do anything after that I get the “Internal Server Error, the server was unable to complete your request.” page. When I check the file system Nextcloud was install; i.e. the config.php was updated, there is data in the data directory, and most importantly there was a nextcloud.log. Blow is the log:
{"reqId":"4A0ilJ4b7bubr7tOj1GN","level":3,"time":"2021-06-06T18:06:02+00:00","remoteAddr":"*** sensitive parameter replaced ***","user":"--","app":"PHP","method":"GET","url":"/cron.php","message":{"Exception":"Error","Message":"filesize(): stat failed for /var/lib/nextcloud/data/flow.log at /var/www/nextcloud/lib/public/Log/RotationTrait.php#62","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"filesize(): stat failed for /var/lib/nextcloud/data/flow.log","/var/www/nextcloud/lib/public/Log/RotationTrait.php",62]},{"file":"/var/www/nextcloud/lib/public/Log/RotationTrait.php","line":62,"function":"filesize","args":["/var/lib/nextcloud/data/flow.log"]},{"file":"/var/www/nextcloud/apps/workflowengine/lib/BackgroundJobs/Rotate.php","line":49,"function":"shouldRotateBySize","class":"OCA\\WorkflowEngine\\BackgroundJobs\\Rotate","type":"->","args":[]},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/Job.php","line":52,"function":"run","class":"OCA\\WorkflowEngine\\BackgroundJobs\\Rotate","type":"->","args":[null]},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/TimedJob.php","line":59,"function":"execute","class":"OC\\BackgroundJob\\Job","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"},{"__class__":"OC\\Log"}]},{"file":"/var/www/nextcloud/cron.php","line":150,"function":"execute","class":"OC\\BackgroundJob\\TimedJob","type":"->","args":[{"__class__":"OC\\BackgroundJob\\JobList"},{"__class__":"OC\\Log"}]}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.77 Safari/537.36","version":"21.0.2.1"} {"reqId":"DTXtSfQ3m8Ricw0DrvAl","level":3,"time":"2021-06-06T18:06:13+00:00","remoteAddr":"*** sensitive parameter replaced ***","user":"morgan","app":"no app in context","method":"POST","url":"/login","message":"Something is wrong with your openssl setup: error:02001002:system library:fopen:No such file or directory, error:2006D080:BIO routines:BIO_new_file:no such file, error:0E064002:configuration file routines:CONF_load:system lib, error:02001002:system library:fopen:No such file or directory, error:2006D080:BIO routines:BIO_new_file:no such file, error:0E064002:configuration file routines:CONF_load:system lib","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.77 Safari/537.36","version":"21.0.2.1"} {"reqId":"DTXtSfQ3m8Ricw0DrvAl","level":3,"time":"2021-06-06T18:06:13+00:00","remoteAddr":"*** sensitive parameter replaced ***","user":"morgan","app":"index","method":"POST","url":"/login","message":{"Exception":"RuntimeException","Message":"OpenSSL reported a problem","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Authentication/Token/PublicKeyTokenProvider.php","line":88,"function":"newToken","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameter replaced ***","*** sensitive parameter replaced ***","*** sensitive parameter replaced ***","*** sensitive parameter replaced ***","*** sensitive parameter replaced ***","*** sensitive parameter replaced ***","*** sensitive parameter replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Authentication/Token/Manager.php","line":71,"function":"generateToken","class":"OC\\Authentication\\Token\\PublicKeyTokenProvider","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/User/Session.php","line":689,"function":"generateToken","class":"OC\\Authentication\\Token\\Manager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/CreateSessionTokenCommand.php","line":68,"function":"createSessionToken","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":40,"function":"process","class":"OC\\Authentication\\Login\\CreateSessionTokenCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/CompleteLoginCommand.php","line":48,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":40,"function":"process","class":"OC\\Authentication\\Login\\CompleteLoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/LoggedInCheckCommand.php","line":60,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":40,"function":"process","class":"OC\\Authentication\\Login\\LoggedInCheckCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/EmailLoginCommand.php","line":58,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":40,"function":"process","class":"OC\\Authentication\\Login\\EmailLoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/UidLoginCommand.php","line":54,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":40,"function":"process","class":"OC\\Authentication\\Login\\UidLoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/UserDisabledCheckCommand.php","line":58,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php","line":40,"function":"process","class":"OC\\Authentication\\Login\\UserDisabledCheckCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/PreLoginHookCommand.php","line":53,"function":"processNextOrFinishSuccessfully","class":"OC\\Authentication\\Login\\ALoginCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/Authentication/Login/Chain.php","line":108,"function":"process","class":"OC\\Authentication\\Login\\PreLoginHookCommand","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/core/Controller/LoginController.php","line":310,"function":"process","class":"OC\\Authentication\\Login\\Chain","type":"->","args":[{"__class__":"OC\\Authentication\\Login\\LoginData"}]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":218,"function":"tryLogin","class":"OC\\Core\\Controller\\LoginController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":127,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OC\\Core\\Controller\\LoginController"},"tryLogin"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":157,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OC\\Core\\Controller\\LoginController"},"tryLogin"]},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OC\\Core\\Controller\\LoginController","tryLogin",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"core.login.tryLogin"}]},{"file":"/var/www/nextcloud/lib/base.php","line":993,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/login"]},{"file":"/var/www/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/nextcloud/lib/private/Authentication/Token/PublicKeyTokenProvider.php","Line":373,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.77 Safari/537.36","version":"21.0.2.1"}
There is a lot in the log, but I am guessing the issue has something to do with openssl as is show up a few times e.g.:
I have checked and the openssl bundle is installed and the PHP openssl module was installed and enabled with the PHP-basic bundle. Is it possible there are some additional PHP or openssl configuration that is needed? Or is it another issue altogether?
