Hello Guys,
I am fairly new to this community, but I am a huge fan of the ClearLinux OS. I have installed it a while ago on my first laptop. Then the laptop broke and I had to buy a new one. My new laptop is the XPS15 7590 with the i9 processor. As I wanted to install the OS according to the guidelines on the website, the installation failed. Through the gui I have seen the cleaning process of the disk is not going through. In other words it failed.
So, as pointed out by the error message, I went to look for more details in the file /root/clr-installer.log, but I do not have any clue what it means. I hope some of you guys is able to help me. The log file contained the following:
2020/11/06 18:14:05 [DBG] Using default shellProxy.DefaultGetProxyValue
2020/11/06 18:14:05 [DBG] [Previous line repeated 4 times]
2020/11/06 18:14:05 [DBG] cmd.Env: []
2020/11/06 18:14:05 [INF] Running pre-install hooks
2020/11/06 18:14:05 [DBG] Clear Linux OS version: latest
2020/11/06 18:14:05 [DBG] lsblk --exclude 1,2,11 -J -b -O /dev/nvme0n1
2020/11/06 18:14:05 [DBG] isBlockDeviceAvailableDeep: Found lvm name: fedora_localhost--live-swap
2020/11/06 18:14:05 [DBG] lvm name fedora_localhost--live-swap does not match Advanced regex \w+-(CLR_[0-9a-zA-Z-_\+.]+$)
2020/11/06 18:14:05 [DBG] isBlockDeviceAvailableDeep: Found lvm name: fedora_localhost--live-home
2020/11/06 18:14:05 [DBG] lvm name fedora_localhost--live-home does not match Advanced regex \w+-(CLR_[0-9a-zA-Z-_\+.]+$)
2020/11/06 18:14:05 [DBG] isBlockDeviceAvailableDeep: Found lvm name: fedora_localhost--live-root
2020/11/06 18:14:05 [DBG] lvm name fedora_localhost--live-root does not match Advanced regex \w+-(CLR_[0-9a-zA-Z-_\+.]+$)
2020/11/06 18:14:05 [INF] Cleaning disk(action): /dev/nvme0n1 with ForceDestructive: false
2020/11/06 18:14:06 [DBG] isBlockDeviceAvailableDeep: Found lvm name: fedora_localhost--live-swap
2020/11/06 18:14:06 [DBG] lvm name fedora_localhost--live-swap does not match Advanced regex \w+-(CLR_[0-9a-zA-Z-_\+.]+$)
2020/11/06 18:14:06 [DBG] isBlockDeviceAvailableDeep: Found lvm name: fedora_localhost--live-home
2020/11/06 18:14:06 [DBG] lvm name fedora_localhost--live-home does not match Advanced regex \w+-(CLR_[0-9a-zA-Z-_\+.]+$)
2020/11/06 18:14:06 [DBG] isBlockDeviceAvailableDeep: Found lvm name: fedora_localhost--live-root
2020/11/06 18:14:06 [DBG] lvm name fedora_localhost--live-root does not match Advanced regex \w+-(CLR_[0-9a-zA-Z-_\+.]+$)
2020/11/06 18:14:06 [DBG] removePart: Found parent: /dev/nvme0n1 for child: /dev/nvme0n1p3
2020/11/06 18:14:06 [DBG] pvdisplay --colon
2020/11/06 18:14:06 [DBG] Using default shellProxy.DefaultGetProxyValue
2020/11/06 18:14:06 [DBG] [Previous line repeated 4 times]
2020/11/06 18:14:06 [DBG] cmd.Env: []
2020/11/06 18:14:06 [DBG] checkVolumeGroupSpan(action): Running with ForceDestructive:false
2020/11/06 18:14:06 [DBG] lvdisplay /dev/mapper/fedora_localhost-live --colon
2020/11/06 18:14:06 [DBG] Pre-Installation has no message content
2020/11/06 18:14:09 [WRN] PrepareInstallationMedia: exit status 5
Error Trace:
errors.Wrap()
/builddir/build/BUILD/clr-installer-2.7.0/errors/errors.go:85
storage.processPhysicalVolume()
/builddir/build/BUILD/clr-installer-2.7.0/storage/block_devices_ops.go:629
2020/11/06 18:14:09 [INF] Running post-image hooks
2020/11/06 18:14:09 [INF] Installation Steps Complete
2020/11/06 18:14:09 [ERR]
Error Trace:
errors.Wrap()
exit status 5
2020/11/06 18:14:09 [DBG] telem-record-gen --severity 3 --class org.clearlinux/clr-installer/tuipanic --no-post --echo --event-id 399b49a43964b2b774b54e702e0ce42d --payload version=2.7.0
exit status 5
Error Trace:
errors.Wrap()
2020/11/06 18:14:09 [DBG] Using default shellProxy.DefaultGetProxyValue
2020/11/06 18:14:09 [DBG] [Previous line repeated 4 times]
2020/11/06 18:14:09 [DBG] cmd.Env: []
2020/11/06 18:14:09 [DBG] dmesg --console-on
2020/11/06 18:14:09 [DBG] telem-record-gen --severity 3 --class org.clearlinux/clr-installer/tui --no-post --echo --event-id 399b49a43964b2b774b54e702e0ce42d --payload version=2.7.0
exit status 5
Error Trace:
errors.Wrap()
2020/11/06 18:14:09 [ERR] exit status 5
Error Trace:
errors.Wrap()
