Freaky error message running PDF4QT AppImage
Can any of you guys make sense of the error messages below? Here’s the context: attempting to run the latest PDF4QT AppImage on my CL computer (42590). Application does not run, and the following error message is being returned:
dad@DadsGram~/Downloads $ ./PDF4QT-1.4.0.0-x86_64.AppImage
warning: direct reference to protected function `_ZNK7QDialog15minimumSizeHintEv' in `/usr/lib64/libQt6Widgets.so.6' may break pointer equality
./PDF4QT-1.4.0.0-x86_64.AppImage: _ZNK7QDialog15minimumSizeHintEv: /usr/lib64/libQt6Widgets.so.6: error due to GNU_PROPERTY_1_NEEDED_INDIRECT_EXTERN_ACCESS
Interestingly, the same AppImage seems to be running fine(?) on my wife’s CL (also 42590); here’s what error message she’s been getting:
mom@MomsSpectre~/Downloads $ ./PDF4QT-1.4.0.0-x86_64.AppImage
qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
mom@MomsSpectre~/Downloads $ qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
qt.svg: Cannot open file ':/pdfplugins/editorplugin/certificates.svg', because: No such file or directory
^C
And here’s the film of the whole operation on my wife’s computer.
Many thanks!
Try :
sudo swupd bundle-add desktop-dev
export QT_QPA_PLATFORM=xcb ./PDF4QT-1.4.0.0-x86_64.AppImage
sudo swupd update
./PDF4QT-1.4.0.0-x86_64.AppImage  --appimage-extract-and-run
For the SVG file issue, it seems the AppImage is having trouble accessing its internal resources.
You can try extracting it and run it directly:
cd squashfs-root
./AppRun
If the above doesn’t work, you might need to set the QT_PLUGIN_PATH environment variable to help Qt find its plugins:
QT_PLUGIN_PATH="$PWD/usr/plugins" QT_QPA_PLATFORM=xcb ./AppRun
Is this supposed to address the GNU_PROPERTY_1_NEEDED_INDIRECT_EXTERN_ACCESS error?
Yes, and if it doesn’t fix it, try :
sudo swupd bundle-add qt-basic
./PDF4QT-1.4.0.0-x86_64.AppImage --no-sandbox
Here goes:
mom@MomsSpectre~/Downloads $ ./PDF4QT-1.4.0.0-x86_64.AppImage --appimage-extract
squashfs-root/.DirIcon
squashfs-root/AppRun
squashfs-root/usr/translations/qt_zh_TW.qm
mom@MomsSpectre~/Downloads $ cd squashfs-root/
mom@MomsSpectre~/Downloads/squashfs-root $ ./AppRun
Here’s also the film.
Edit: Interestingly, when run with QT_PLUGIN_PATH="$PWD/usr/plugins" QT_QPA_PLATFORM=xcb ./AppRun, the Could not find the Qt platform plugin "wayland" error does not show up! The app still fails with the Failed to start process './Pdf4QtViewer error.
did you :
Yes, qt-basic has been installed since the very beginning, as a matter of routine.
