Gsmartcontrol does not run
i have compiled gsmartcontrol. Program is installed. I have program icon in dasbord.
But when i run gsmartcontrol from terminal command not found.
What did you type at the terminal ?
The right command is smartctl
To permanently enable it for a drive, use :
# smartctl -s on -o on /dev/sda
