Dear All,
does anyone else have broken HP printers in 31440 ( HP envy 4257 )
Clear-Linux has stopped printing after the last update
Thanks
Whitty
Dear All,
Thanks
Whitty
I solved by installing ghostscript.
swupd bundle-add ghostscript
Ghostscript should be included by default in the desktop
bundle, but in the latest version it disappeared from my system…
So i decided to manually install it and now everything works
Interesting. I did move ghostscript into a separate bundle, but, everything that depended on it should have automatically received it through dependencies.
I had issue before 31440 (HP DeskJet 3720-use 3700 all-in one seris driver).
First i install ghostscript but the issue remain,now all work,i use Generic IPP Everywhere driver.
Before with both driver (generic and 3700 series) i have issue.
I install driver trough cups because in gnome settings I not fund my network printer.
Lovely
I do enjoy the interaction and teamwork when I find bugs and problems
Thank you guys will test out when I return from work
Thank you very much
Yes when I removed it.
I went to install it, and kde could find it again
In fact the printer control panel did not do much at all
And “hp-setup -i” could not find the printer either
Hope the info helps
Perhaps the ghostscript bundle should be a hard include
(rather than also-add) in the hardware-printing
bundle to ensure it is always there as many printers will want it in some way.
I agree. It worth being conservative for hardware related bundles.
