Please
How Can i install Dock in Clear Linux Desktop??
Thank You
you need to add extension - https://extensions.gnome.org/
Most challenging part is to install the host connector - Projects/GnomeShellIntegration/Installation - GNOME Wiki!
Links to two docks that work well:
https://extensions.gnome.org/extension/307/dash-to-dock/
https://extensions.gnome.org/extension/3730/floating-dock/
Best
Thank you very much Nikolay_k.
