My pc runs on core i5/8gb ram with a generic monitor. I don’t have any dedicated gfx card. When i install windows primarily my desktop screen has a 4:3 aspect ratio with 1024*768 resolution. However after performing an update i can change the screen resolution to 1920×1080. I thought the same thing would happen if i install & update CL. But i can’t find anything on how to change my screen resolution. Only for this reason i had to come back to windows. How do i solve this issue?
sorry to bother you. i went to the gnome-control-center as you said. it just opened the settings that’s all. i already searched for everything in the settings. i specifically want to know how do i update the display driver for CL.
harold@clr-e0aa3815e4874c6fa98c3407aee0a88d~ $ xrandr
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 16384 x 16384
VGA-1 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.00*
800x600 60.32 56.25
848x480 60.00
640x480 59.94
to make the custom resolution permanent the tutorial said to create an ~/.xprofile.
but it didn’t say how to do it, where to do it. after scouring the internet for hours i found the command sudo gedit ~/.xprofile to do so. it opened an empty file. i was dumbfounded! i didn’t say that by default the there is no “.xprofile file” and I had to add the custom mode to it.
why this tutorials are so counterintuitive?
I guess I would have to farther inspect that toutorial to understand why you would go sudoing aroung your home directory?
I don’t get it. does not rightclicking ne ware in desktop and simply going into settings>desplay set it until the monitors are somehow changed or rearranged unplugged swapped etc
thatswhatidoworksfineeverytime
Windows doesn’t requires a command/text editor/powershell to create a file. Just right click & you can create folder,file, whole lot of other things from the pop up men.
