How to convert a iso file to a bootable usb drive?
Before flash:
- Download etcher (balenaEtcher - Flash OS images to SD cards & USB drives)
1.4.5. (for linux users only) Right-click on the file
1.9.0 Select properties and tick “Allow as executable” - Once it has finished downloading open the (file or appimage and or folder)
- Once it has loaded choose “Flash from file”
- Choose the usb and click “Flash”
After flash:
- Reboot your computer, but as soon as the boot logo shows press the key the allows you into the boot menu (Defers between manufacturer)
- Choose the usb you flashed
2.5 press enter - And your done
With the pretty pictures - https://docs.01.org/clearlinux/latest/get-started/bootable-usb.html#bootable-usb
sudo dd if=/home/you/Downloads/clr-linux-x.iso of=/dev/sdx && sync
where /dev/sdx is your unmounted usb. find it with lsblk. Unmount it wth sudo umount /dev/sdx.
Double check it’s the right one first with fdisk -l | grep Disk because if you get the wrong one you could accidentally wipe your hard drive.
https://clearlinux.org/software/flathub/fedora-media-writer
Fedora Media Writer does the job nicely.
Use Ventoy for multiple OS instead.
- Open GNOME Disks
- On the left panel click on the device you want to use
- Click on the three dots on the upper right
- Click “Restore Disk Image”
- Select the .iso file in “Image to Restore”
- Click “Start Restoring”
