I created write the downloaded iso to usb drive from gnome-disk-utility from debian. When I bootthe boot menu appears sucessfully but when i choose to boot selecting clear linux it stuck there. nothing happens. What can i do now?
It’s recommended to follow the tutorial to make the ISO.
Yeah, balenaEtcher works flawlessly. I’ve never had a problem since I started using it.
can’t i even use dd?
You can, in fact that option is also listed in the Clear Linux tutorial https://docs.01.org/clearlinux/latest/get-started/bootable-usb.html#advanced-linux-cli.
I’ve noticed however that balenaEtcher tends to be faster, at least that’s my perception.
I suggested using balenaEtcher as default method in the tutorial, for it is much faster in general than dd and avoids many issues.
I agree. There was time when I would reboot just to get to rufus, which for awhile was the only way I knew to quickly create reliable iso boot media. Not anymore. BelenaEtcher is excellent, and very reliable.
ok i will go with etcher then…
There’s Yumi too, in case Etcher doesn’t work for you.
