Hey. I’ve been looking for fast linux distro and it seems like clearlinux is the best i’ve found so far.
The only thing i don’t get is how to enable and customize zram and make it high priority? I tried searching on internet already but i was not able to find anything related to that subject about clearlinux.
You are welcome, if you are looking to learn how to config you can use that guide, YouTube and join a dev community for support. Also some guys here would most likely help.
Maybe it will help you or someone else, I use this repo to setup zram swap on ClearLinux. It works fine since as said above, it is kernel-level feature and not that really disto dependent.
The instructions in the repo work as is, just make sure you have git locally with swupd bundle-add git and after the service is run, check the swaps with cat /proc/swaps
