Very latest Clear Linux version update as of 9/24/2020 breaks Clear Linux for my PC? Intel i5 ASUS Z170 mb AMD XFX fury R9 gpu. On reboot white screen contact your admin unhappy face,
I guess I will use this update version for a long time now. Otherwise I will have to change distro, de, I don’t know. Because I actually need to use my computer for work, and any update now gnome breaks something. Jesus.
Please keep in mind that it’s best not to go very long without running the update manually. The last time I saw a comment on that, one of the Clear Linux team recommend about once a week. But I first check the forums here to see whether anyone has reported any problems after auto-updates. I try to run it every weekend, and it usually only takes a few minutes to complete. My system runs 24 x 7 so I do a restart after the update.
Just updated mine and for some reason it inputs the letter “t” every time I press enter😅 Been using this on and off for the past few years now but first time encountering that issue.
