I was attempting to build this flatpak: Rene Bon Ćirić (Renich) / BitwigStudio Flatpak · GitLab
First issue:
Can’t use the --install-deps-from=flathub flag for flatpak-builder in the Makefile I think because these deps are installed by clear linux?
So run these commands instead:
flatpak-builder --force-clean -v build com.bitwig.BitwigStudio.yaml
flatpak-builder --force-clean -v --repo=repo repo-build com.bitwig.BitwigStudio.yaml
Second issue:
We get the error:
Can’t find source path /etc/ld.so.cache: No such file or directory
This can be solved with:
sudo ln -snf /var/cache/ldconfig/ld.so.cache /etc/ld.so.cache
I don’t know if there is a better way of solving the above.
Third issue:
Couldn’t get jack to work and worked around it by making an empty jack-config file:
touch ~/.BitwigStudio/jack-config
Finally:
We need to install the flatpak so run:
flatpak-builder --user --install --force-clean build com.bitwig.BitwigStudio.yaml
Should now be available as an app for you to start.
Enjoy!
