audacious media player
I launch VLC using $ LD_LIBRARY_PATH=/usr/local/lib vlc
. The same should work for Audacious, I think.
this doesnt work for me. my ffmpeg is the static binaries and i put it in /opt/bin/
. LD_LIBRARY_PATH=/opt/bin
doesnt either work. truth be told, it isnt that bad, as i can use ffmpeg to convert audio files
