Did you install Clear Linux using virtualization? If yes, try decreasing the number of CPU cores to 8. The GUI and text-based installer will fail somewhere above 8 virtual CPU cores. Increasing to desired vCPUs and memory after the installation and power off is fine.
Hello thanks for the help, I tell you is a clean installation on my personal computer, hp elitebook 840 g5, has an intel i5 8350vPro. I have already tried several solutions but it still gives me the same error
