Is it possible to downgrade single packages?
Since I ran into an issue related to a bug with binutils 2.34 I’d like to downgrade only this package to the previous version. Is it possible to do this with swupd?
Clear Linux versions bundles for the whole operating system. It is not possible to downgrade individual packages.
You would have to either build the package yourself, rollback the whole operating system to an older version, or wait for a fix from our team.
Thanks for the answer. I think I’ll wait another week for the team to solve the issue #1741. If there are other priorities at the moment I’ll than try to apply the proposed patch. Keep up the good work!
@GonerGenesis the fix is available now
Please update to the latest Clear Linux release.
