Is it safer to use Bleachbit on ClearLinux?
Its hard to decide whether using Bleachbit on a optimized environment like Clear Linux is safer to use or not, I haven’t test it out yet also the Flatpak version doesn’t work as expected, I may have to compile from source. is it safer to use on Clear Linux?
I’m not familiar with Bleachbit, but you can run sudo swupd repair after any runs of Bleachbit to fix (if any) system file modifications and you should be good to go. You may read more about how ClearLinux separates user and system files here clear-linux-documentation/source/guides/clear/stateless.rst at 27f38877993f8173ebbd5c261a24060a25e4267f · clearlinux/clear-linux-documentation · GitHub
