I am trying to get KDEs PIM tools installed and working. I installked the Kontact flatpack. However, I am missing applications that are supposed to be included, such as Korganizer. Also, when I attempt to launch Kmail, it quits with the message:
The Email program encountered a fatal error and will terminate now.
The error was:
Unable to obtain agent type ''.
From the googling I have done, I understand that I should be able to get some useful info from Akonadi Console, but nothing seems to be there. And when I try to read the Akonadi Console Handbook under Help Center, the documentation seems to be missing:
`The file or folder help:akonadiconsole does not exist.`
Edit: It seems that all my help files are missing, so that last part probably isn’t relevant.
Are there other bundles I need to install? Build something myself?
