Hello, I just installed the desktop-kde
bundle and rebooted my PC. Now I am welcomed by the login screen but when I enter my password and try to login whether on Plasma or Gnome the laptop just shows me the login screen again and freezes completely (cannot even access the terminal). Something must be conflicting but what is it?
PC freezes after login after installing KDE
I remember that you had NVIDIA Optimus but have you configured that for KDE?
Oh no, I didn’t do anything, I just installed the bundle and restarted the PC.
Well aside from the NVIDIA driver, you may need to disable gdm and enable sddm in systemd.
Could you elaborate on that please? I run systemctl disable gdm
and systemctl enable sddm
. I have the exact same behaviour.
But have you configured sddm as you configured gdm with Optimus support?
@Qushy I’ve experienced something similar with Intel graphics + kernel 5.2 and plasma. I’m not sure if it’s the same issue, but if you’re running the Plasma session powered by Intel graphics, please try adding i915.enable_psr=0 to the kernel command line. There was an i915 bug in kernel 5.2 with fix already merged, but it seems Plasma can trigger a different one quite easily.
OK I wrote the following in /etc/sddm.conf
and now the PC boots into Plasma randomly without asking for a password:
[Autologin]
Session=plasma.desktop
User=<username>
But I think I’ve pinned down the problem to startx
looking in /usr/share/X11/xorg.conf.d
and not finding the correct .conf files so it can’t find a screen. /usr/share/X11/xorg.conf.d
contains some AMD conf files but I’m on NVidia Optimus. How can I fix that? I’ve looked online and haven’t found a solution yet.
EDIT: Ok, I’ve tried a lot of things, the problem is that startx
completely freezes the PC with “Screens found but none have a usable configuration” and Xorg -configure
fails with “Number of created screens does not match number of detected devices”.
Post the files you mentioned here
I’m afraid I can’t do that, I only have a Manjaro Deepin Live USB and it won’t connect to the internet. There is a line also reading “Failed to acquire modesetting permission”. I think this is causing all the fuss.
Did you update the system first before adding bundle?
and I am running plasma didn’t have to enable or disable anything , just install kde bundle and reboot
Oh no I haven’t updated the system before adding the bundle, however I managed to boot in Plasma randomly one time and updated then.
Ok the system randomly booted in Plasma again. Here’s the /var/log/Xorg.1.log
[ 3.156] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 3.156] _XSERVTransMakeAllCOTSServerListeners: server already running
[ 3.157] (--) Log file renamed from "/var/log/Xorg.pid-622.log" to "/var/log/Xorg.1.log"
[ 3.158]
X.Org X Server 1.20.5
X Protocol Version 11, Revision 0
[ 3.158] Build Operating System: Linux 5.2.3-809.native x86_64
[ 3.158] Current Operating System: Linux clr-0f4eaf6da210492b95c072e104c6ba68 5.2.10-828.native #1 SMP Mon Aug 26 11:01:27 PDT 2019 x86_64
[ 3.158] Kernel command line: initrd=\EFI\org.clearlinux\freestanding-00-intel-ucode.cpio initrd=\EFI\org.clearlinux\freestanding-i915-firmware.cpio.xz root=PARTUUID=91528963-80ad-4d44-8173-b309baf5b134 quiet console=tty0 console=ttyS0,115200n8 cryptomgr.notests init=/usr/bin/initra-desktop initcall_debug intel_iommu=igfx_off kvm-intel.nested=1 no_timer_check noreplace-smp page_alloc.shuffle=1 rcu_nocbs=0-64 rcupdate.rcu_expedited=1 rootfstype=ext4,btrfs,xfs tsc=reliable rw module.sig_unenforce i915.enable_psr=0
[ 3.158] Build Date: 31 May 2019 06:47:02PM
[ 3.158]
[ 3.158] Current version of pixman: 0.38.4
[ 3.158] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 3.158] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 3.158] (==) Log file: "/var/log/Xorg.1.log", Time: Fri Aug 30 20:40:19 2019
[ 3.158] (==) Using config file: "/etc/X11/xorg.conf"
[ 3.158] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3.158] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3.158] (==) ServerLayout "layout"
[ 3.158] (**) |-->Screen "nvidia" (0)
[ 3.158] (**) | |-->Monitor "<default monitor>"
[ 3.158] (**) | |-->Device "nvidia"
[ 3.158] (**) | |-->GPUDevice "intel"
[ 3.158] (**) | |-->GPUDevice "Device0"
[ 3.158] (==) No monitor specified for screen "nvidia".
Using a default monitor configuration.
[ 3.158] (**) |-->Inactive Device "intel"
[ 3.158] (==) Automatically adding devices
[ 3.158] (==) Automatically enabling devices
[ 3.158] (==) Automatically adding GPU devices
[ 3.158] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3.158] (==) FontPath set to:
/usr/share/fonts/X11/misc/,
/usr/share/fonts/X11/TTF/,
/usr/share/fonts/X11/OTF/,
/usr/share/fonts/X11/Type1/,
/usr/share/fonts/X11/100dpi/,
/usr/share/fonts/X11/75dpi/
[ 3.158] (**) ModulePath set to "/opt/nvidia/lib64/xorg/modules,/usr/lib64/xorg/modules"
[ 3.158] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 3.158] (II) Loader magic: 0x5568ab4f4020
[ 3.158] (II) Module ABI versions:
[ 3.158] X.Org ANSI C Emulation: 0.4
[ 3.158] X.Org Video Driver: 24.0
[ 3.158] X.Org XInput driver : 24.1
[ 3.158] X.Org Server Extension : 10.0
[ 3.159] (++) using VT number 1
[ 3.160] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c2
[ 3.161] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 3.161] (EE) systemd-logind: failed to take device /dev/dri/card1: Invalid argument
[ 3.161] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 3.162] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 1
[ 3.162] (EE) Error systemd-logind returned paused fd for drm node
[ 3.162] (II) systemd-logind: releasing fd for 226:0
[ 3.164] (--) PCI:*(0@0:2:0) 8086:591b:1028:0802 rev 4, Mem @ 0xdb000000/16777216, 0x70000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 3.164] (--) PCI: (1@0:0:0) 10de:1c20:1028:0802 rev 161, Mem @ 0xdc000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 3.164] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 3.164] (II) LoadModule: "glx"
[ 3.165] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 3.165] (II) Module glx: vendor="X.Org Foundation"
[ 3.165] compiled for 1.20.5, module version = 1.0.0
[ 3.165] ABI class: X.Org Server Extension, version 10.0
[ 3.165] (II) LoadModule: "nvidia"
[ 3.165] (II) Loading /opt/nvidia/lib64/xorg/modules/drivers/nvidia_drv.so
[ 3.166] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 3.166] compiled for 1.6.99.901, module version = 1.0.0
[ 3.166] Module class: X.Org Video Driver
[ 3.166] (II) LoadModule: "modesetting"
[ 3.166] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 3.166] (II) Module modesetting: vendor="X.Org Foundation"
[ 3.166] compiled for 1.20.5, module version = 1.20.5
[ 3.166] ABI class: X.Org Video Driver, version 24.0
[ 3.166] (II) NVIDIA dlloader X Driver 435.17 Tue Aug 6 22:56:56 CDT 2019
[ 3.166] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 3.166] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3.166] (II) Loading sub module "fb"
[ 3.166] (II) LoadModule: "fb"
[ 3.166] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 3.166] (II) Module fb: vendor="X.Org Foundation"
[ 3.166] compiled for 1.20.5, module version = 1.0.0
[ 3.166] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3.166] (II) Loading sub module "wfb"
[ 3.166] (II) LoadModule: "wfb"
[ 3.166] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 3.166] (II) Module wfb: vendor="X.Org Foundation"
[ 3.166] (II) Loading sub module "ramdac"
[ 3.166] (II) LoadModule: "ramdac"
[ 3.166] (II) Module "ramdac" already built-in
[ 3.167] (WW) Falling back to old probe method for modesetting
[ 3.167] (EE) Screen 1 deleted because of no matching config section.
[ 3.167] (II) UnloadModule: "modesetting"
[ 3.167] (II) NVIDIA(0): Creating default Display subsection in Screen section
"nvidia" for depth/fbbpp 24/32
[ 3.167] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 3.167] (==) NVIDIA(0): RGB weight 888
[ 3.167] (==) NVIDIA(0): Default visual is TrueColor
[ 3.167] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 3.167] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 3.167] (**) NVIDIA(0): Enabling 2D acceleration
[ 3.167] (II) Loading sub module "glxserver_nvidia"
[ 3.167] (II) LoadModule: "glxserver_nvidia"
[ 3.167] (II) Loading /opt/nvidia/lib64/xorg/modules/extensions/libglxserver_nvidia.so
[ 3.171] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 3.171] compiled for 1.6.99.901, module version = 1.0.0
[ 3.171] Module class: X.Org Server Extension
[ 3.171] (II) NVIDIA GLX Module 435.17 Tue Aug 6 22:54:03 CDT 2019
[ 3.171] (II) NVIDIA: The X server does not support PRIME Render Offload.
[ 3.173] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 3.173] (--) NVIDIA(0): DFP-0
[ 3.173] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1060 with Max-Q Design (GP106-A) at
[ 3.173] (II) NVIDIA(0): PCI:1:0:0 (GPU-0)
[ 3.173] (--) NVIDIA(0): Memory: 6291456 kBytes
[ 3.173] (--) NVIDIA(0): VideoBIOS: 86.06.57.00.3d
[ 3.173] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 3.173] (EE) NVIDIA(GPU-0): Failed to acquire modesetting permission.
[ 3.173] (EE) NVIDIA(0): Failing initialization of X screen
[ 3.173] (II) UnloadModule: "nvidia"
[ 3.173] (II) UnloadSubModule: "glxserver_nvidia"
[ 3.173] (II) Unloading glxserver_nvidia
[ 3.173] (II) UnloadSubModule: "wfb"
[ 3.173] (II) UnloadSubModule: "fb"
[ 3.173] (EE) Screen(s) found, but none have a usable configuration.
[ 3.173] (EE)
Fatal server error:
[ 3.173] (EE) no screens found(EE)
[ 3.174] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 3.174] (EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
[ 3.174] (EE)
[ 3.235] (EE) Server terminated with error (1). Closing log file.
Hello my friend.
Something like that happened to me in linux mint. The problem was that when I installed an app, there seemed to be corrupt and uninstalled dependencies and this was the problem. The solution was to enter console mode (not desktop) and execute the following command:
apt-get dist-upgrade
It is worth trying the following commands later:
apt-get autoremove
apt-get autoclean
apt-get update
apt-get -f install
I think these commands have to do with Debian and not Clear Linux, but thanks for the suggestions anyway.
So what I meant by configuring sddm as you configured gdm
is to modify /usr/share/sddm/scripts/Xsetup
instead of creating /usr/local/share/optimus.desktop
According to the guide, this is what it’s needed for sddm
, which is the default desktop manager for kde
So have you done this?
I’m trying to setup KDE Plasma as well, and got exacttly the same issues (laptop with Nvidia card). While following the Medium guide works for GNOME, in KDE it shows the login screen but when entering the password it just kicks me out.
UPDATE
I tried following the Arch Linux NVIDIA Optimus guide to setup Plasma, using SSDM, but got no luck. Only solution has been removing the desktop-kde bundle at once, since I couldn’t even use GNOME anymore
UPDATE 2
So, the problem I have now is this: the KDE graphical login screen shows up, and I can choose a bunch of DEs (GNOME, Plasma, Weston, on Xorg or Wayland). I tried to launch all of them but the same thing happens with every one: you enter the password, the screen goes black for a split second, then it kicks you back again to the login screen. Here are the errros from the Xorg log:
Xorg.1.log Errors
[ 3.281] (EE) systemd-logind: failed to take device /dev/dri/card1: Invalid argument
[ 3.282] (EE) Error systemd-logind returned paused fd for drm node
[ 3.293] (EE) NVIDIA(GPU-0): Failed to acquire modesetting permission.
[ 3.293] (EE) NVIDIA(0): Failing initialization of X screen
[ 3.293] (EE) Screen(s) found, but none have a usable configuration.
[ 3.293] (EE)
[ 3.293] (EE) no screens found(EE)
[ 3.293] (EE)
[ 3.293] (EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
[ 3.293] (EE)
[ 3.316] (EE) Server terminated with error (1). Closing log file.
here’s the whole log:
Xorg.1.log
[ 3.277] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 3.277] _XSERVTransMakeAllCOTSServerListeners: server already running
[ 3.277] (--) Log file renamed from "/var/log/Xorg.pid-812.log" to "/var/log/Xorg.1.log"
[ 3.277]
[ 3.277] Build Operating System: Linux 5.2.3-809.native x86_64
[ 3.277] Current Operating System: Linux MSICL 5.2.13-832.native #1 SMP Fri Sep 6 04:11:36 PDT 2019 x86_64
[ 3.277] Kernel command line: initrd=\EFI\org.clearlinux\freestanding-00-intel-ucode.cpio initrd=\EFI\org.clearlinux\freestanding-i915-firmware.cpio.xz root=PARTUUID=f4d5ccb3-ce74-47a1-a0da-81c542b14e09 quiet console=tty0 console=ttyS0,115200n8 cryptomgr.notests init=/usr/bin/initra-desktop initcall_debug intel_iommu=igfx_off kvm-intel.nested=1 no_timer_check noreplace-smp page_alloc.shuffle=1 rcu_nocbs=0-64 rcupdate.rcu_expedited=1 rootfstype=ext4,btrfs,xfs tsc=reliable rw module.sig_unenforce module_blacklist=i915
[ 3.277] Build Date: 31 May 2019 06:47:02PM
[ 3.277]
[ 3.277] Current version of pixman: 0.38.4
[ 3.277] Before reporting problems, check http://wiki.x.org
[ 3.277] Markers: (--) probed, (**) from config file, (==) default setting,
[ 3.277] (==) Log file: "/var/log/Xorg.1.log", Time: Tue Sep 10 19:37:17 2019
[ 3.277] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3.277] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3.278] (==) No Layout section. Using the first Screen section.
[ 3.278] (==) No screen section available. Using defaults.
[ 3.278] (**) |-->Screen "Default Screen Section" (0)
[ 3.278] (**) | |-->Monitor "<default monitor>"
[ 3.278] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 3.278] (**) | |-->Device "nvidia"
[ 3.278] (==) No monitor specified for screen "Default Screen Section".
[ 3.278] (==) Automatically adding devices
[ 3.278] (==) Automatically enabling devices
[ 3.278] (==) Automatically adding GPU devices
[ 3.278] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3.278] (==) FontPath set to:
[ 3.278] (**) ModulePath set to "/usr/lib64/xorg/modules,/opt/nvidia/lib64/xorg/modules"
[ 3.278] (II) The server relies on udev to provide the list of input devices.
[ 3.278] (II) Loader magic: 0x560cef1d8020
[ 3.278] (II) Module ABI versions:
[ 3.278] X.Org ANSI C Emulation: 0.4
[ 3.278] X.Org Video Driver: 24.0
[ 3.278] X.Org XInput driver : 24.1
[ 3.278] X.Org Server Extension : 10.0
[ 3.279] (++) using VT number 1
[ 3.280] (II) systemd-logind: took control of session /org/freedesktop/login1/session/c2
[ 3.281] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 3.281] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 3.282] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 1
[ 3.282] (II) systemd-logind: releasing fd for 226:0
[ 3.284] (--) PCI:*(0@0:2:0) 8086:191b:1462:11d5 rev 6, Mem @ 0xdd000000/16777216, 0xb0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 3.284] (--) PCI: (1@0:0:0) 10de:1c20:1462:11d5 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 3.284] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 3.284] (II) "glx" will be loaded by default.
[ 3.284] (II) LoadModule: "modesetting"
[ 3.284] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 3.284] (II) Module modesetting: vendor="X.Org Foundation"
[ 3.284] compiled for 1.20.5, module version = 1.20.5
[ 3.284] Module class: X.Org Video Driver
[ 3.284] ABI class: X.Org Video Driver, version 24.0
[ 3.284] (II) LoadModule: "glx"
[ 3.284] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 3.285] (II) Module glx: vendor="X.Org Foundation"
[ 3.285] compiled for 1.20.5, module version = 1.0.0
[ 3.285] ABI class: X.Org Server Extension, version 10.0
[ 3.285] (II) LoadModule: "nvidia"
[ 3.285] (II) Loading /opt/nvidia/lib64/xorg/modules/drivers/nvidia_drv.so
[ 3.285] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 3.285] compiled for 1.6.99.901, module version = 1.0.0
[ 3.285] Module class: X.Org Video Driver
[ 3.285] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3.285] (II) NVIDIA dlloader X Driver 435.17 Tue Aug 6 22:56:56 CDT 2019
[ 3.286] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 3.286] (WW) Falling back to old probe method for modesetting
[ 3.286] (II) Loading sub module "fb"
[ 3.286] (II) LoadModule: "fb"
[ 3.286] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 3.286] (II) Module fb: vendor="X.Org Foundation"
[ 3.286] compiled for 1.20.5, module version = 1.0.0
[ 3.286] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3.286] (II) Loading sub module "wfb"
[ 3.286] (II) LoadModule: "wfb"
[ 3.286] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 3.286] (II) Module wfb: vendor="X.Org Foundation"
[ 3.286] (II) Loading sub module "ramdac"
[ 3.286] (II) LoadModule: "ramdac"
[ 3.286] (II) Module "ramdac" already built-in
[ 3.286] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 3.286] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 3.286] (==) NVIDIA(0): RGB weight 888
[ 3.286] (==) NVIDIA(0): Default visual is TrueColor
[ 3.286] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 3.286] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 3.287] (**) NVIDIA(0): Enabling 2D acceleration
[ 3.287] (II) Loading sub module "glxserver_nvidia"
[ 3.287] (II) LoadModule: "glxserver_nvidia"
[ 3.287] (II) Loading /opt/nvidia/lib64/xorg/modules/extensions/libglxserver_nvidia.so
[ 3.291] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 3.291] compiled for 1.6.99.901, module version = 1.0.0
[ 3.291] Module class: X.Org Server Extension
[ 3.291] (II) NVIDIA GLX Module 435.17 Tue Aug 6 22:54:03 CDT 2019
[ 3.291] (II) NVIDIA: The X server does not support PRIME Render Offload.
[ 3.292] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 3.292] (--) NVIDIA(0): DFP-0
[ 3.292] (--) NVIDIA(0): DFP-1 (boot)
[ 3.292] (--) NVIDIA(0): DFP-2
[ 3.293] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1060 (GP106-A) at PCI:1:0:0 (GPU-0)
[ 3.293] (--) NVIDIA(0): Memory: 3145728 kBytes
[ 3.293] (--) NVIDIA(0): VideoBIOS: 86.06.29.00.04
[ 3.293] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 3.293] (II) UnloadModule: "nvidia"
[ 3.293] (II) UnloadSubModule: "glxserver_nvidia"
[ 3.293] (II) Unloading glxserver_nvidia
[ 3.293] (II) UnloadSubModule: "wfb"
[ 3.293] (II) UnloadSubModule: "fb"
[ 3.293] (EE)
Fatal server error:
[ 3.293] (EE)
for help.
[ 3.293] (EE)
@doct0rHu any ideas to solve this?
UPDATE:
It looks like that, with the latest CL build and the latest Nvidia drivers, everything is working as it should. Plasma is very cool, although it seems quite bugged (themes won’t install and stuff like that). But this seems more of a problem on Plasma side
Hey.
I’m seeing a lot of the above mentioned issues on a pure intel machine so some of your issues may not be entirely Nvidia related.
For me to get a stable KDE experience I had to remove everything gnome including gdm (had both display managers running) AND NOT select the wayland session.
[edit] typo
Sorry for the late reply. I was very busy since my school started.
Recently Gnome cannot starts with NVIDIA driver, so I’m wondering it might also affect you.
Let’s wait until this is fixed and then try Optimus.
