Hi ,
A simple way to install Lazarus Ide
Installation
swupd bundle-add wget;
swupd bundle-add package-utils;
wget "https://download-ib01.fedoraproject.org/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/l/lazarus-2.2.2-2.fc37.x86_64.rpm" --no-check-certificate;
rpm2archive lazarus-2.2.2-2.fc37.x86_64.rpm ;
tar xvf lazarus-2.2.2-2.fc37.x86_64.rpm.tgz -C / ;
wget "https://download-ib01.fedoraproject.org/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/f/fpc-3.2.2-7.fc37.x86_64.rpm" --no-check-certificate;
rpm2archive fpc-3.2.2-7.fc37.x86_64.rpm ;
tar xvf fpc-3.2.2-7.fc37.x86_64.rpm.tgz -C / ;
wget "https://download-ib01.fedoraproject.org/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/f/fpc-src-3.2.2-7.fc37.noarch.rpm" --no-check-certificate;
rpm2archive fpc-src-3.2.2-7.fc37.noarch.rpm ;
tar xvf fpc-src-3.2.2-7.fc37.noarch.rpm.tgz -C / ;
wget "https://download-ib01.fedoraproject.org/pub/fedora/linux/releases/37/Everything/x86_64/os/Packages/f/fpc-doc-3.2.2-7.fc37.x86_64.rpm" --no-check-certificate;
rpm2archive fpc-doc-3.2.2-7.fc37.x86_64.rpm ;
tar xvf fpc-doc-3.2.2-7.fc37.x86_64.rpm.tgz -C / ;
Configuration
1 ) Inital Setup
2 ) To have a Delphi 8 & sup Look and feel
- Packet / Install Packets choose and install AnchorDockingDsgn 1.0
Make a simple bash test project
Project / New project :
Install the following 5 elements on the form ( drap and drop or click and click )
- Standard / TLabel
- Standard / TEdit ( I named it Edit_1_Bash_To_Send_ )
- Standard / TButton ( I named it Button_1_SendToBash )
- Standard / TMemo ( I named it Memo_1_Answer_ )
- System / TProcessUFT8 Add Proterty / option / poUsePipes ( poPassInout if needed )
Add Button Click Event ( double click on Button )
- Add these 3 instructions
(* Basic test program for CLear Linux OS *)
ProcessUTF8_1.CommandLine:= Edit_1_Bash_To_Send_.Text;
ProcessUTF8_1.Execute;
Memo_1_Answer_.Lines.LoadFromStream(ProcessUTF8_1.Output);
Run the programm ( Ctrl + F9 )
- Test the program on a simple way sending : who etc …
- Test the program on a more complex way sending :
xrandr --output yourScreenName --brightness 0.6 ;
( works also perfect on external Displays )
Best Regards,
ClearLinux.User.809
