After giving sudo mixer build bundles --native in mix directory.
some packages expecting dependency libraries like below.
nothing provides libevent-2.1.so.7()(64bit) needed by ****
nothing provides libtelemetry.so.4()(TM_2_0_0)(64bit) needed by ****.
Clearlinux version: 28100 (Desktop-version)
libevent-2.1.so.6 & libtelemetry.so.3 are present in the /usr/lib64/ directory
Cannot upgrade OS version as it is the requirement.
how to upgrade the libraries without updating the OS?
