Kindly how can install Mesa 22 and Vulkan-Loader (libvulkan1) I did do search by doing sudo swupd search for both but nothing came out
$ sudo swupd search-file libvulkan
[100%]
Searching for ‘libvulkan’
Bundle binutils [installed] (383 MB on system)
/usr/share/clear/optimized-link-scripts/scripts.ld/–usr–lib64–libvulkan.so.1.3.269.ld
/usr/share/clear/optimized-link-scripts/scripts.gold/–usr–lib64–libvulkan.so.1.3.269.gold
Bundle devpkg-Vulkan-Loader [installed] (7950 MB on system)
/usr/lib64/libvulkan.so.1.3.270
Bundle lib-opengl [installed] (2717 MB on system)
/usr/lib64/libvulkan_radeon.so
/usr/lib64/libvulkan_lvp.so
/usr/lib64/libvulkan_intel_hasvk.so
/usr/lib64/libvulkan_intel.so
Bundle qt-basic [installed] (4060 MB on system)
/usr/lib64/qt5/plugins/wayland-graphics-integration-client/libvulkan-server.so
Bundle wine (1920 MB to install)
/usr/lib64/wine/libvulkan-1.a
/usr/lib32/wine/libvulkan-1.a
/usr/lib32/libvulkan_radeon.so
/usr/lib32/libvulkan_lvp.so
/usr/lib32/libvulkan_intel_hasvk.so
/usr/lib32/libvulkan_intel.so
/usr/lib32/libvulkan.so.1.3.270
how can
so doI copy for /usr/lib64/wine/libvulkan-1.a into the terminal or how does it work
Search the repo using the search-file
command like he’s shown you and add the bundle you want to install with bundle-add
// eg:
sudo swupd bundle-add wine
so for example sudo swupd bundle-add /libvulkan-1.a am I getting right
no, search-file
shows each instance of your file being found in the repo
the bundle is shown as a “heading”
[100%]
as you can see, Bundles qt-basic
and wine
both have hits for the search
you can see that this bundle is already installed with the [installed] moniker
this bundle can be installed as it says.
So
- find out the bundle name of what you need
- run
bundle-add
with that name - profit
