My question is why Clear Linux does not include all the linux kernel headers? My second question is what is the best way to go about adding them?
I was trying to use the <linux/slab.h> header and I noticed it is not in the clear linux system.
Is this really hard to find?
Maybe I misunderstand what you’re trying to say doc. I understand the file is in linux. However I do not think it is in the clear linux build. For example, when I type:
$ locate slab.h
I only get:
/usr/include/dns/rdataslab.h
swupd search-file slab.h
You can for example install linux-dev bundle
Thank you! It hadn’t occurred to me to use the swupd to get it. I has assumed since it wasn’t already installed that it’s not possible to install easily.
For anyone else who sees this, doc’s answer worked.
I also recommend looking at this: https://docs.01.org/clearlinux/latest/guides/kernel/kernel-modules.html
