pCloud drive no mount
I have installed pCloud, it is a my backup for pretty much everything. The app runs, but it doesn’t see the network drive that is produced when the app is running. Not sure if this is fixable.
It may make things hard for me using Clear…
Can you use rclone (bundle: rclone) to connect to your pCloud instance? See e.g. pCloud
If I see it correctly, the official pcloud linux app is an appimage(?), which would significantly limit the chance that it can be fixed by others.
Which method did you use?
I’ve just downloaded the latest version :
$ chmod +x pcloud (from where the file is located)
and start it with :
$ ./pcloud
After that, you just have to check the box : start pcloud drive on system startup
And everything works fine
