When trying to debug something in R, it came to my attention that libRblas might not be linked to R the way it’s supposed to be. I’m not sure what it is supposed to be though. I do have the openblas bundle installed.
$ ldd /usr/lib64/R/bin/exec/R
linux-vdso.so.1 (0x00007ffeec3b9000)
libR.so => not found
libRblas.so => not found
libgomp.so.1 => /usr/lib64/libgomp.so.1 (0x00007feb27ef2000)
libpthread.so.0 => /usr/lib64/libpthread.so.0 (0x00007feb27ecf000)
libc.so.6 => /usr/lib64/libc.so.6 (0x00007feb27cdb000)
/lib64/ld-linux-x86-64.so.2 => /usr/lib64/ld-linux-x86-64.so.2 (0x00007feb27f7b000)
In what regard? ldd only shows the system paths which it’s not in. R does add the necessary path mainly via /usr/bin/R and /usr/lib64/R/etc/ldpaths so they are found when opened. libRblas.so is basically a wrapper (only 18232 bytes) around openblas (as that’s what is used in CL).
If R wasn’t able to find those files, it wouldn’t load. Renaming the files to libR.so.asdf leads to:
$ R
/usr/lib64/R/bin/exec/R: error while loading shared libraries: libR.so: cannot open shared object file: No such file or directory
Ok thanks, but it seems to have something to do with the R internals (although still possibly a version difference in some library). I traced the difference to this call in R’s eigen() function:
z <- if (!complex.x)
.Internal(La_rs(x, only.values))
else .Internal(La_rs_cmplx(x, only.values))
