When I try to install anything in the software centre it gets stuck on pending installation.
I’ve attached some logs, the thing that stands out are the errors I get for flatpak?
09:44:46:0127 GLib-GObject specified class size for type 'GsFlatpakTransaction' is smaller than the parent type's 'FlatpakTransaction' class size
09:44:46:0127 GLib g_once_init_leave: assertion 'result != 0' failed
09:44:46:0127 GLib-GIO g_initable_new_valist: assertion 'G_TYPE_IS_INITABLE (object_type)' failed
09:44:46:0127 Gs flatpak did not set error for gs_plugin_app_install
