I have three updates in “Software” app. I clicked install to install all of them yesterday. The updates are still not installed.
I’ve cancelled and tried to install again. That hasn’t worked either.
Any tips on what may be wrong?
thanks
thanks
See if there are any relevant logs using journalctl -xe and/or try launching gnome-software from a terminal with gnome-software --verbose.
If it is sandboxed software (see details), the first time, it take a while (5 minutes) because you download the common softwares used by flatpak. You can, in this case, use flatpak list, flatpak search and flatpak install flathub software_name in a terminal to see what appends. You can also use the system monitor.
Sorry for my poor English
Thanks for all the help
Only warning I could find that may be related is:
“Warning: Failed to get revokefs-fuse socket from system-helper: User flatpak does not exist in password file entry”
Saw the above when I ran “flatpak update” manually.
Running it manually updated all the software just fine and now gnome-software shows all software is up to date.
Seeing the same issue on another CL box I have. Will run “flatpak update” manually on it as well.
This is probably unrelated and reported upstream: Failed to get revokefs-fuse socket from system-helper: User flatpak does not exist in password file entry · Issue #2959 · flatpak/flatpak · GitHub
@theflakes FYI - this bug (Unable to install Flatpak applications via Software after clean installation · Issue #901 · clearlinux/distribution · GitHub) was resolved in CL version 30020. Try again after updating.
