Hello all!
I am attempting to setup WiFi on a Dell XPS 13 9300. The card in question is a Killer AX1650.
I found this page from killer that seems to indicate I should be able to use the Intel® Wi-Fi 6 AX200 160MHz firmware found here.
I have downloaded said firmware and placed it into /etc/firmware/
but this has not seemed to resolve my problem.
The first thing that is confusing me is that when running
modinfo iwlwifi | grep firmware
I am not seeing the new firmware I added show up in the list:
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-ty-a0-gf-a0-52.ucode
firmware: iwlwifi-so-a0-gf-a0-52.ucode
firmware: iwlwifi-so-a0-hr-b0-52.ucode
firmware: iwlwifi-so-a0-jf-b0-52.ucode
firmware: iwlwifi-cc-a0-52.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-52.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-52.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-52.ucode
firmware: iwlwifi-Qu-b0-jf-b0-52.ucode
firmware: iwlwifi-Qu-c0-hr-b0-52.ucode
firmware: iwlwifi-QuQnj-a0-hr-a0-52.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-52.ucode
firmware: iwlwifi-QuQnj-f0-hr-a0-52.ucode
firmware: iwlwifi-Qu-a0-jf-b0-52.ucode
firmware: iwlwifi-Qu-a0-hr-a0-52.ucode
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: fw_monitor:firmware monitor - to debug FW (default: false - needs lots of memory) (bool)
Nor do I see any attempt to load the firmware when starting up. Here is what I pulled from dmesg
[ 54.045870] calling iwl_drv_init+0x0/0x1000 [iwlwifi] @ 516
[ 54.045997] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 54.049419] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-52.ucode failed with error -2
[ 54.049568] initcall iwl_drv_init+0x0/0x1000 [iwlwifi] returned 0 after 628 usecs
[ 54.049582] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-51.ucode failed with error -2
[ 54.049605] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-50.ucode failed with error -2
[ 54.049621] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-49.ucode failed with error -2
[ 54.049637] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-48.ucode failed with error -2
[ 54.049783] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-47.ucode failed with error -2
[ 54.049804] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-46.ucode failed with error -2
[ 54.049820] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-45.ucode failed with error -2
[ 54.049835] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-44.ucode failed with error -2
[ 54.049851] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-43.ucode failed with error -2
[ 54.049868] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-42.ucode failed with error -2
[ 54.049884] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-41.ucode failed with error -2
[ 54.049899] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-40.ucode failed with error -2
[ 54.049914] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-Qu-b0-hr-b0-39.ucode failed with error -2
[ 54.049916] iwlwifi 0000:00:14.3: no suitable firmware found!
[ 54.050714] iwlwifi 0000:00:14.3: minimum version required: iwlwifi-Qu-b0-hr-b0-39
[ 54.051546] iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-Qu-b0-hr-b0-52
[ 54.052403] iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
I’m still pretty new to linux so reading through this nothing is standing out to me, wondering I could get some help narrowing down the problem.
