Dear All,
When booting, I’m getting the following error:
iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-56.ucode failed with error -2
The WiFi works properly, but I’m wondering where this error comes from.
There is no iwlwifi-cc-a0-56.ucode in the /usr/lib/firmware/ directory, only the file iwlwifi-cc-a0-59.ucode.
Could it be a typo somewhere: 9 mistaken for a 6?
Who could answer this question?
Thanks for your help.
Complete trace from dmesg:
[ 1.253547] calling iwl_drv_init+0x0/0x1000 [iwlwifi] @ 261
[ 1.253581] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[ 1.261645] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-56.ucode failed with error -2
[ 1.261819] initcall iwl_drv_init+0x0/0x1000 [iwlwifi] returned 0 after 2709 usecs
[ 1.265339] iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
[ 1.265347] iwlwifi 0000:02:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22
[ 1.265348] iwlwifi 0000:02:00.0: Found debug destination: EXTERNAL_DRAM
[ 1.265349] iwlwifi 0000:02:00.0: Found debug configuration: 0
[ 1.265507] iwlwifi 0000:02:00.0: loaded firmware version 55.d9698065.0 cc-a0-55.ucode op_mode iwlmvm
[ 1.278476] calling iwl_mvm_init+0x0/0x1000 [iwlmvm] @ 304
[ 1.278487] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 1.451522] iwlwifi 0000:02:00.0: base HW address: 14:f6:d8:83:40:69
[ 1.464383] initcall iwl_mvm_init+0x0/0x1000 [iwlmvm] returned 0 after 144906 usecs
[ 1.466008] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
